Date/Time: Wed, 25 Nov 2026 16:14:57 +0000
Print Drawing Time
View Count: 501
[2025-08-06 23:05:46]
User688525 - Posts: 403
Hello Sierra,
Is it possible to print the time (anchor time) of a drawing? For example, if a Horizontal Ray is drawn from a bar at 13:15, is there a way to include the time (anchor time) in the text which could then be modified (Modify Text)?
Thank you
Date Time Of Last Edit: 2025-08-07 07:10:49
[2025-08-07 14:12:40]
Apart from manually doing this, the only way to do it automatically would be through a custom study. Refer to the following:
Using Drawing Tools From an Advanced Custom Study: s_UseTool::BeginDateTime
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
[2025-08-07 23:34:36]
Thank you John.
