Date/Time: Wed, 25 Nov 2026 16:15:00 +0000
v2781 - Occasional exceptions when calling sc.GetAttachedOrderIDsForParentOrder
View Count: 493
[2025-08-06 14:25:13]
User907968 - Posts: 887
Per the title, in v2781 I am occasionally seeing access violation exceptions thrown when calling sc.GetAttachedOrderIDsForParentOrder.
The exceptions only occur in one specific context - when using an order ID from a recent fill as the ParentInternalOrderID argument.
I am not using this approach anymore, I solved my problem a different way, but thought it made sense to mention it.
Also, calls to the same function elsewhere in the system have not been seen to throw, but in those cases the order ID comes from iterating through the orders list.
I should add that the system was built using older headers, v2566, if that has any bearing on the situation.
Date Time Of Last Edit: 2025-08-06 14:34:50
[2025-08-06 20:31:15]
Sierra_Chart Engineering - Posts: 25481
Thank you. This will be fixed in the next release.
There was indeed a problem.
