Date/Time: Wed, 25 Nov 2026 16:15:11 +0000
Different type of transactions on two different tapes
View Count: 488
| [2025-08-06 12:01:27] |
| User493651 - Posts: 2 |
Hi, im learning from guy who uses TOS and I can see that we have two different types of transaction on tape. Screen is below. |
| Attachment Deleted. |
| [2025-08-06 14:09:23] |
We do not compare to other systems. There are too many options that could be set one way or another to be able to make a direct comparison. Our data matches what the exchanges send. We have verified this multiple times. The only way we would look into this is if you are comparing to data directly from the exchange. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
