Date/Time: Wed, 25 Nov 2026 16:15:06 +0000
How to Display Candlesticks with Both Volume Profile and TPO Enabled
View Count: 1060
| [2025-08-06 09:58:22] |
| Zosko243 - Posts: 1 |
Hello, When I enable both the Volume Profile and TPO studies at the same time, my candlesticks disappear, which is very frustrating. I would really appreciate your help in getting my candlesticks to appear behind the profiles. I’ve done some research and tried everything I could, but nothing seems to work. |
| Attachment Deleted. |
| [2025-08-06 13:57:04] |
There is no option for displaying candlesticks with a TPO chart. The closest you can come to this is to display the TPO as "Letters/Blocks in Own Column". There is a right-click option to do this for individual profiles or for all profiles. There is also an Input that allows you to define how you want the display to be by default. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Displaying TPO Letters/Blocks for Subperiod in Own Column Time Price Opportunity (TPO) Profile Charts: Default Column Display Style (For All Profiles) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
