Date/Time: Wed, 25 Nov 2026 16:14:57 +0000
I need help with setting up my charts
View Count: 443
| [2025-08-05 17:33:26] |
| User323723 - Posts: 1 |
I do not want candle stick charts I just want a white background with black bars. I also need a list of margins for all the cme markets. Thank you R |
| [2025-08-05 21:23:28] |
Refer to the following for the chart display options available: Graph Draw Types Refer to the following as a starting place for the coloring options for the chart displays: Graphics Settings: Bar High-Low Down Margins are set by your broker. You need to talk to them about this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
