Date/Time: Wed, 25 Nov 2026 16:14:57 +0000
Rectangle tool config
View Count: 542
| [2025-08-04 22:33:09] |
| User629461 - Posts: 213 |
If a rectangle tool is drawn and sitting over the top of an existing line or text drawing, its almost impossible to select the line/txt only without disturbing the rectangle and messing everything up. Is there a 'push to back' function (eg. similar to PowerPoint) where it sends the rectangle drawing to the back, or a config option to specify that the rectangle can only be selected by its edges, thereby not selecting the rectangle when trying to select another drawing/tool? Its quite frustrating.
Date Time Of Last Edit: 2025-08-04 22:39:07
| [2025-08-05 04:04:38] |
| Sierra_Chart Engineering - Posts: 25481 |
Yes there is an option for this: Global Settings >> Tool Settings >> General >>Support Interior Rectangle Selection:No Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
