Date/Time: Wed, 25 Nov 2026 16:14:56 +0000
Charting: universal Renko Bars
View Count: 483
| [2025-08-04 21:37:19] |
| User793203 - Posts: 2 |
I've tried to setup the Universal Renko Bars that are explained: I have the regular Renko bars but looking for the universal as you have in the documentation... I copied my settings for you below:
| [2025-08-04 21:37:31] |
What exactly is the question?
| [2025-08-05 04:21:56] |
Sorry, I am trying to get the correct data to place UniRenko Bars on Chart... I supplied my settings so you guys can look over to see if anything can be changed, to correct my issue.
| [2025-08-05 15:17:05] |
We haven't had "Universal Renko Bars" named as such, since 2017. We do not know what exactly you are looking for in terms of the Universal Renko, so we can not give a specific answer. We have set this as a "User Discussion" for others to give their feedback on how they use this. Someone may know what you are looking for. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-05 23:59:36] |
| cmet - Posts: 747 |
Change 10-9-1 to 10-1-9 For your Renko Bar New Bar Mode, use: New Trend Bar After Range Met | Allow Change of Direction of Current Bar |
