Date/Time: Wed, 25 Nov 2026 16:15:01 +0000
Sierra Chart Package 11 - Unsure if Teton or CQG
View Count: 966
| [2025-08-04 19:33:49] |
| jcheha01 - Posts: 7 |
I have paid for Sierra Chart Package 11. I have my Amp Futures account setup to route through Teton. I am still getting a "Logon Unsuccesful. Contact your FCM error. Should I have setup Amp with CQG? I am unsure of how Denali fits into all of this as well. |
| [2025-08-04 20:45:43] |
If you are only trading the CME Group, then we highly recommend using the Teton Order Routing service. It is far superior in terms of stability and process times, and it can save you some funds as well (there is no Order Routing fee). As to whether you are setup to use Teton or CQG, you need to check with AMP first. Find out which one you are setup to use with them. Then go through the appropriate setup instructions for that service: If you are setup with CQG, then follow these instructions: CQG Trading Platform Service: Setup Instructions If you are setup with Teton, then follow these instructions, starting at Step #6: Sierra Chart Teton Futures Order Routing: Setup Instructions -- In either case, you will need to use our Denali Exchange Data Feed. We do not have support for data from CQG for the CME Group and EUREX; and if you are using Teton, then you have no other choice but to use this data. You are already setup with the following exchange for the CME Group: - CME with Market Depth for Non-Professional Trading Accounts So you should be fine with regards to the data, unless you need data for symbols that are traded on the other exchanges that make up the CME Group (CBOT, COMEX, and NYMEX). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
