Date/Time: Wed, 25 Nov 2026 16:15:04 +0000
SC2776 - 'Move Stops To Price' does not work anymore
View Count: 518
[2025-08-04 14:21:38]
User512353 - Posts: 198
SC2776
With (unchanged) attached settings, when right-clicking into Buy or Sell column in the Trade DOM does not move the stops anymore.
Problem since SC 2776.
Right click into Buy or Sell column to place a Trailing Stop still works.
imageScreenshot from 2025-08-04 14-14-25.png / V - Attached On 2025-08-04 14:16:49 UTC - Size: 35.8 KB - 269 views
[2025-08-04 14:24:34]
updated from SC2773
SC2775 was skipped
[2025-08-04 18:57:03]
We are able to reproduce this and will look into it.
[2025-08-04 21:36:41]
Can you provide an estimate when this will be fixed?
I use this function a lot with manual trades.
If it will take a long time to fix this, I would consider downgrading.
[2025-08-05 14:00:20]
We have passed this along to Engineering to look into. They typically fix issues like this fairly quickly - so a day or two is what we would expect. But we can not say for certain.
If you want to downgrade, then follow these instructions:
Software Download: Full Control Rollback Procedure
[2025-08-06 11:36:08]
SC2781 still shows the error.
[2025-08-07 11:40:36]
The problem seems to be resolved with SC2782.
Thanks!
[2025-08-07 11:48:40]
Sierra_Chart Engineering - Posts: 25481
Yes. We will explain what the problem was.
There was a change recently made where when using the commands Move Stops/Targets to Price, that they would only move sell orders when in the sell column and only move buy orders when in the buy column.
We thought this was a good safety feature but clearly caused a problem for some users with how you have them configured.
