Date/Time: Wed, 25 Nov 2026 16:14:57 +0000
Customize Trading Command
View Count: 529
[2025-08-01 19:34:59]
User573371 - Posts: 5
Can you please make the addition to add a "quantity" field in the shortcuts so I can quickly buy 1 market, buy 2 market, buy 3 market etc? This would be very helpful and seemingly easy to accomplish.
Attaching screenshot for further reference.
Thanks,
imageScreenshot 2025-08-01 153139.png / V - Attached On 2025-08-01 19:32:09 UTC - Size: 64.1 KB - 263 views
[2025-08-01 20:18:34]
Your request has been noted. We can not say when we would get to any particular request.
Just so you are aware, you can setup different "Trading Configurations" to have different quantities and you can assign these trading configurations to Control Bar Buttons which can then be mapped to Keyboard Shortcuts (you need to setup the Control Bar Button, even if you do not display it, and then you can assign the Keyboard Shortcut to do the same thing as that Control Bar button).
This will allow you to change the quantity with one keyboard shortcut and then place the order with another.
Refer to the following:
Basic Trading and the Trade Window: Selecting/Using a Trade Window Configuration
