Date/Time: Wed, 25 Nov 2026 16:15:02 +0000
Is it possible to get the source for for the study 'Large volume trade indicator'?
View Count: 524
| [2025-08-01 14:36:18] |
| User154791 - Posts: 15 |
As the title says, is it possible to get the source code for this indicator? I am looking to build some extra functionalities on top of it, however I am unable to replicate it at the moment and the source code would help a lot.
| [2025-08-01 15:10:13] |
| Sierra_Chart Engineering - Posts: 25481 |
Refer to: How to Build an Advanced Custom Study from Source Code: Source Code for Some Built in Studies Not Available Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-03 00:00:11] |
| ForgivingComputers.com - Posts: 1256 |
No. Some studies are not available. The source code is available if there is a box on the Study Settings window labelled DLLName.FunctionName below the Protect with Password check box. You will find the study's source code if you search for the FunctionName in the contents of the CPP files in the c:\SierraChart\ACS_Source folder. This is easily done in Notepad++ with Ctrl-Shift-F. Date Time Of Last Edit: 2025-08-03 00:00:50
