Date/Time: Wed, 25 Nov 2026 16:25:01 +0000
6J scale between Daily and hourly chart is different?
View Count: 502
| [2025-07-31 15:58:21] |
| User288938 - Posts: 39 |
Hello, So Im running into an issue with just 6J contract where if i draw a line on the daily chart at a low of a candle. When I go onto the hourly chart, the line is at the same price, but it isnt at the low anymore. I've attached a screen shot. My settings are the same across the board for both the charts Date Time Of Last Edit: 2025-07-31 16:10:31
Private File |
| [2025-07-31 16:03:13] |
For one thing, you are using a Back Adjusted Continuous Futures chart type in your Daily chart, but the 1 hour chart is not back-adjusted. This is most likely the reason. But, it could also, at least partially, be due to the following: Historical Chart Prices: 12.1 - Historical Daily Bars Session Times and Evening Session Trading For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
