Date/Time: Wed, 25 Nov 2026 16:25:15 +0000
Blank spaces in number bar candles
View Count: 510
[2025-07-31 02:27:35]
PathogenX90 - Posts: 1
HI There,
Attached is a screenshot from my number bar candles. There is a lot of blank spaces in the chart. And if I increase the tick size, the data in a single candle goes out of bounds. Please help.
imageScreenshot 2025-07-31 142223.png / V - Attached On 2025-07-31 02:25:51 UTC - Size: 124.6 KB - 247 views
imageScreenshot 2025-07-31 142507.png / V - Attached On 2025-07-31 02:26:02 UTC - Size: 176.86 KB - 255 views
[2025-07-31 15:28:06]
That data is from Global Data Feeds - India. You would need to talk to them about it. It is definitely not an issue with our Numbers Bars study.
One item of note, we do not recommend changing the Tick Size. If you want to accumulate the data for the Numbers Bars (and other Volume studies) for multiple prices into a single level, then use the "Volume At Price Multiplier". Refer to the following:
Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu)
