Date/Time: Wed, 25 Nov 2026 16:15:09 +0000
historical fill data for last two months
View Count: 536
| [2025-07-30 17:18:53] |
| User312651 - Posts: 11 |
I an attempt to have my laptop and desktop show fill data, I deleted the data that I did have, and then realized it only has 3 weeks of rolling data available for insertion into. Is it possible to get access to that last two months during a limited window and I'll be sure not to delete it going forward? Thanks in advance. -ryan |
| [2025-07-30 17:25:39] |
You have the "CME E-Mini for Professionals" exchange active. If you are referring to data for a symbol that is part of that exchange, then there is no 3 week limit. You can get as much historical data as we have available (which typically is back to 2011 unless the symbol started trading more recently. Refer to the following: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-02 02:21:30] |
Thanks for looking into this. I am referring to my historical trades. Currently I only have back to 7/6. -ryan |
| [2025-08-02 17:30:39] |
| Sierra_Chart Engineering - Posts: 25481 |
Longer-term order fill history is available over the weekend with Teton order routing. Refer to: Trade Activity Log: Automatically Inserting Missing Order Fills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
