Date/Time: Wed, 25 Nov 2026 16:25:09 +0000
How to use label columns?
View Count: 770
[2025-07-30 16:51:46]
neevaksama - Posts: 78
I followed the instructions here: Global Trade Settings Windows: Label Column to make my numbers show up on those columns
However, they still don't appear (I have tried reversing color just in case as well).
Sub question: After enabling Trade >> Show Market Data Columns, the bid and ask numbers appeared. I just enabled it as per the instructions to use that horizontal alignment; anyway to not show the bid/ask numbers?
imagesc-issue2.png / V - Attached On 2025-07-30 16:51:13 UTC - Size: 165.28 KB - 295 views
[2025-07-30 17:00:06]
You do not have the Label column displayed. Refer to the following to add the "Label" column:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
If you do not want to see the "Bid Size" and "Ask Size" columns, then with the option for "Show Market Data Columns" enabled, and the option for "Trading Chart DOM On" disabled, set the columns to be displayed as the "Buy Order" and "Sell Order" columns. In this case, the Buy/Sell columns will not actually display.
Note that you have to have something selected for the Bid/Buy and Ask/Sell columns.
