Date/Time: Wed, 25 Nov 2026 16:25:05 +0000
How to link Trade and Current Quote Symbol?
View Count: 1102
[2025-07-29 05:39:06]
MarkusK - Posts: 126
I usually chart minis but trade micros. So, under Chart Settings > Symbol, I e.g. have "Symbol" set to "ES" but "Trade and Current Quote Symbol" to "MES" (along with the option "Use As Trade Only Symbol" set to "Yes").
I linked my charts (via Chart > Linking > Symbol) because I wanted an easy way to change the symbol simultaneously in all my charts.
However, I noticed that the Chart Linking > Symbol option doesn't help me here, since it only changes the "Symbol", but not the "Trade and Current Quote Symbol".
E.g., when I change the symbol from ES to NQ, I still have to open every single chart in my chartbook and manually change the "Trade and Current Quote Symbol" from MES to MNQ.
This makes the Chart Linking > Symbol option rather pointless (at least in this scenario).
Is there any (other) way to link the "Trade and Current Quote Symbol" as well together with the actual charted symbol?
[2025-07-29 13:42:06]
In the Linking there is a separate option for "Trade/Quote Symbol". Make sure this is also set to "Yes" for linked charts in order to update that item.
[2025-07-29 14:33:46]
Thank you very much for the fast response, John. I completely overlooked this setting (because I expected it to be located at the top of the list next to the Symbol option). Mea culpa!
However, unless I'm missing something else, I think I found a bug in SC:
I have two charts: chart A and chart B. Both are linked and the options "Symbol" and "Trade/Quote Symbol" are both enabled under Linking.
When I change the trade and current quote symbol in chart A, it's properly updated in chart B as well.
But: Some of the Symbol Settings (under Chart Settings >> Symbol) in chart B are not updated correspondingly.
I noticed that specifically the "Currency Value Per Tick" setting is not updated unless I manually open the Chart Settings of chart B and click on "Apply Global Symbol Settings".
Could that be a bug in SC, or am I missing something here?
[2025-07-29 16:23:37]
Sierra_Chart Engineering - Posts: 25481
We will check on this.
