Date/Time: Wed, 25 Nov 2026 16:25:06 +0000
Chart with fixed 24 hr x axis?
View Count: 502
[2025-07-28 21:48:52]
User212833 - Posts: 18
Id like to make a chart with a fixed, 24 hr x axis displayed (12am at the left limit and 12am the following say at the right limit) ....I would like price to progressively work its way across the chart (left to right through the fill space) as the day goes on.
Can you think of a way to do this?......limiting data loaded to 1 day does not seem to work
[2025-07-29 03:40:30]
Sierra_Chart Engineering - Posts: 25481
Yes should be no problem if you set the Chart >> Chart Settings >> Session Times to:
00:00:00 (Start)
23:59:59 (End)
And set the Days To Load for Intraday Chart Data Type to 1 and once the new day begins, Reload the chart with Chart >> Reload and Recalculate.
Date Time Of Last Edit: 2025-07-29 03:41:35
