Date/Time: Wed, 25 Nov 2026 16:25:07 +0000
Custom Text Scroller Study
View Count: 529
| [2025-07-28 19:51:20] |
| G369 - Posts: 27 |
Hi, I want to build a custom text scroller study to display Candlestick patterns from region 0 to display scrolling commentary in region 1/2. I tried different techniques. The study and text displayed in different regions. I needed your input to solve this problem. regards N |
| [2025-07-28 20:01:05] |
We really need more information on what you are trying to do. Please give us specific information on what you want to accomplish.
| [2025-07-28 21:33:24] |
| G369 - Posts: 27 |
I want a running commentary on the different candle sticks patterns developed in ACSIL to be show as “inverted hammer @ price 14646.00” one line commentary of the current or previous candle sticks. Like this a scrolling text box in region 1 or 2. Like ACSIL is giving me sports commentary.
| [2025-07-28 21:43:46] |
If you are building this using ACSIL, then the easiest way to do this is to create a text drawing at the bar and price level you want. If these are to just show in a different region, then you could use a price of 1.00 for all the text drawings, for instance. But it will depend on how many drawings you would end up with and how close together. Refer to the following: Using Drawing Tools From an Advanced Custom Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
