Date/Time: Wed, 25 Nov 2026 16:25:06 +0000
Support for separate 30 minute VP
View Count: 510
[2025-07-28 19:43:31]
User748475 - Posts: 4
Hi. I need help with creating a separate 30 minute volume profile on my TPO chart that is fixed in half an hour increments. Right now the 30 minute period just rolls over at the start instead of starting again. Please help!
[2025-07-28 20:00:01]
If you are wanting multiple 30 minute Volume by Price profiles on a TPO chart, then you would have to create them individually. There is not a way to use the option for Multiple Volume by Price Profiles on a TPO chart, except for the same period as the TPOs themselves (i.e. if the TPOs are 1 day, then you can have 1 day Volume by Price profiles).
To add a Volume by Price profile to a TPO chart that is separate from the TPOs, refer to the following:
Volume By Price Study: 30 Minute Volume Profile at End of TPO Profile Chart
As noted above, if you want more than one, you would have to add them each individually and set the particular times for the time period you want.
It would be easiest to use a separate chart for the 30 minute Volume by Price profiles.
