Date/Time: Wed, 25 Nov 2026 16:25:00 +0000
SC subscription (Denali Data) vs Topstep trader login credentials
View Count: 573
| [2025-07-28 15:51:00] |
| Shores2021 - Posts: 59 |
Hello, Do I need an active & paid SC credentials (for example Package #10 for $36 or other) to be able to login with Topstep Trader credential and use their paid for Rithmic data? I believe during their evaluation I could use their Rithmic credentials but my SC account seems expired and enabled for other login data feed logins/credentials. Thank you very much. Tom Date Time Of Last Edit: 2025-07-28 15:51:29
| [2025-07-28 18:45:53] |
Although you can use Sierra Chart with an expired account, you can not get any new data and there are some limitations on the software itself. Therefore, to get data from Rithmic, you do have to have an active account. Your account is currently expired, so you can not connect. Your account is currently set to renew to Package 10 for 1 month. So as soon as you add funds equal to or greater than $36.00, your account will automatically renew to that package. If you want a different package, then you would need to change that prior to adding funds. Refer to the following instructions: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
