Date/Time: Wed, 25 Nov 2026 16:25:11 +0000
[Programming Help] - Same Symbol Settings?
View Count: 466
| [2025-07-28 15:22:04] |
| AlexH4 - Posts: 28 |
i am trying to understand how symbol setting work and from what i see the ticker that i am trading (everyday is a different one) is using <symbol>????</symbol> or some time <symbol>???</symbol> and both have the same setting!?!? What i am trying to do is edit SymbolSettings.scdataallservices in sierra chart folder to make it super simple lightweight by removing everything except us stock that i have with my subscription [US Equities - Consolidated Tape (UTP & CTA)] and create one symbol setting is it possible? thx for any help really appreciate!!! |
| [2025-07-28 16:05:57] |
| Sierra_Chart Engineering - Posts: 25481 |
You definitively cannot edit this file: SymbolSettings.scdataallservices.xml Any changes will simply be ignored and overwritten. To understand symbol settings, refer to: Global Symbol Settings You can create new symbol settings for a specific symbol or a symbol pattern. When using a pattern, you need to enable this option for the particular symbol settings: Global Symbol Settings: Use Pattern Matching Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-28 16:06:11
