Date/Time: Wed, 25 Nov 2026 16:25:09 +0000
Trade Logs Multiple Computers
View Count: 524
| [2025-07-28 14:32:44] |
| user_xyz - Posts: 529 |
If I merge the Trade Trade Activity Log folder across multiple computers will SC recognize this and display ALL the trades for the day in the Trade Activity Log and Charts accordingly? TradeActivityLog_2025-07-28_UTC.xxx_1.data (ex PC1 2 trades 8am and 9am est) TradeActivityLog_2025-07-28_UTC.xxx_2.data (ex PC2 1 trade 11am est) Goal is when the log files are copied in the TradeActivityLogs folder both PC's would display ALL 3 trades. |
| [2025-07-28 15:18:27] |
| Sierra_Chart Engineering - Posts: 25481 |
Yes this will work, but make sure you do this, when Sierra Chart is not running. When you add trade activity files, Sierra Chart must be restarted to detect them. Since Sierra Chart internally maintains a fast lookup cache of the file names.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-28 15:18:42
