Date/Time: Wed, 25 Nov 2026 16:25:04 +0000
ORDER FILLS CONNECTING LINES
View Count: 582
| [2025-07-26 00:27:26] |
| User143203 - Posts: 2 |
I BEEN HAVING THIS PROBLEM FOR SOMETIME ON AND OFF MY ORDER FILLS LINES ARE CONNECTING TRADES FROM DAYS AGO TO TRADES ON THE CURRENT DAY THAT HAVE NOTHING TO DO WITH EACH OTHER IVE CHECKED MOST OF THE SETTINGS AND CANT FIND THE ISSUE I DONT KNOW IF ITS SIERRA CHARTS SYSTEM THANKYOU
| [2025-07-26 18:33:32] |
| Sierra_Chart Engineering - Posts: 25481 |
Refer to: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
