Date/Time: Wed, 25 Nov 2026 16:25:00 +0000
Ratio Study
View Count: 499
| [2025-07-25 18:24:10] |
| User841161 - Posts: 357 |
I am trying to use Study Divide/Ratio. It seems like it is not calculating right-study is giving me 1.0102 value. When I manually calculate I am getting 6428.25/6394.04= 1.00535, not sure the difference.
| [2025-07-25 19:45:04] |
You have the "Study 2 Subgraph Offset" set to "1". This means that the ratio is going to be done with a specific bar from the Main Price Graph with the bar one back in Study 2. Set this to zero and see if you get what you expect.
