Date/Time: Thu, 26 Nov 2026 04:33:41 +0000
Values to display in the compact tool value window
View Count: 1177
| [2025-07-25 13:27:35] |
| Fabio - Posts: 155 |
Good morning, I've updated to the latest version this morning (2776) and after the update the compact tool value window started to display fields I am not interested in. I know I can go in the settings of each and every chart and decide what to show and what not to, however, I have 24 chartbooks with 7 charts each...There must be something that can be done globally, right? Also, this happened with the update across 4 different instances of SC and it has nothing to do with me messing up with the settings. I just updated SC and this new fields popped up. Do you know how to fix that problem in a way that it doesn't require like 3 weeks for me to be done? Thanks in advance, Fabio. |
| [2025-07-25 14:55:22] |
| Sierra_Chart Engineering - Posts: 25491 |
We will implement a solution to this in the next release. Yes this is true: I know I can go in the settings of each and every chart and decide what to show and what not to, Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-25 14:56:15
| [2026-05-08 06:51:27] |
| TraderBake - Posts: 63 |
Is there a solution for this?
