Date/Time: Wed, 25 Nov 2026 16:25:14 +0000
Spread Study Question
View Count: 527
| [2025-07-24 16:11:44] |
| User413206 - Posts: 48 |
At the 5:00 mark, the presenter enters spread entry price. https://www.sierrachart.com/index.php?page=doc/VideoLibrary.php&Video=SierraChart_Spread_Order_Entry_Study What if I don't want to wait for a price level and wish to enter at market? Is that possible or do I have to leg in with two separate DOMs? |
| [2025-07-24 18:26:39] |
In order to enter at market directly, you would just have to ensure that the "Spread Entry Price" is either above or below the current market price as defined by the "Spread Entry Price Operator". For example, if the current spread price is 50.00, and the "Spread Entry Price Operator" is "Less or Equal", then if you set the "Spread Entry Price" to be 50 or above, then you will have the orders sent at the then market prices. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
