Date/Time: Wed, 25 Nov 2026 16:25:00 +0000
Numbers Bars: Use Separate Colors for text coloring method
View Count: 536
[2025-07-23 20:23:44]
Cesium - Posts: 179
Is there a way to use this setting for only select columns as opposed to all columns simulatneously or no columns at all
[2025-07-23 20:57:37]
There is not a way to do this only for select columns. The option for using separate text coloring applies to all or none.
[2025-07-24 10:12:25]
Sébastien - Posts: 156
There is a hack to this.
You can use multiple instances of the Number Bars study and overlap them.
