Date/Time: Wed, 25 Nov 2026 16:25:09 +0000
Keeping track of studies being referenced by other studies in Chart Studies Window?
View Count: 539
| [2025-07-23 04:31:46] |
| pjk0225 - Posts: 44 |
I'm building out a trading system using simple Chart Alerts, primarily using the "Color Background based on alert condition" study. There are more than a hundred such studies all referencing other custom studies. When I have to change a study ID number for whatever reason, I have to manually check which studies are being affected and update them manually. Is there a safer, more consistent method of doing this in Sierra Chart? |
| [2025-07-23 14:38:33] |
| Sierra_Chart Engineering - Posts: 25481 |
No there is not an easier way to do this. Although custom studies are able to get and change study Inputs for any other study within the Chartbook. So a custom study could perhaps help with this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-23 14:39:21
| [2025-07-23 15:31:52] |
Although custom studies are able to get and change study Inputs for any other study within the Chartbook. Could you elaborate on this? |
| [2025-07-23 15:44:31] |
You can change the Input of another study within a custom study. Refer to the following: ACSIL Interface Members - Functions: sc.SetChartStudyInputFloat() Therefore, if you were to change the reference for a study, you could use a custom study to update other studies. But, in the end, it would be best, overall, to just use a custom study to do what you want, since you state that you have over one hundred studies. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
