Date/Time: Wed, 25 Nov 2026 16:25:15 +0000
Combining two different cumulative delta charts into one single graph
View Count: 516
[2025-07-22 20:19:01]
ChrisX - Posts: 14
Is it possible to combine the mini and micro contract cumulative deltas (for example, the S&P500 futures) into one dataset/graph? I don't want two separate graphs. As the micro is smaller in price I want to be able to compensate for the difference between the two. I want to be able to see how the combined cumulative deltas behave relative to the price chart.
[2025-07-22 20:53:53]
The first thing to do would be to use the "Study/Price Overlay" to get the "Cumulative Delta" graph from one chart to the other. Then you would use one (or more) of the following studies to manipulate the data as you want:
- Bar Difference
- Multiply Charts - Bar
- Ratio - Bar
- Spreadsheet Formula - Bar
- Sum - Bar
- Spreadsheet Study
Depending on how you want to combine the data, the "Spreadsheet Formula - Bar" is probably the best option as it gives you more flexibility.
