Date/Time: Wed, 25 Nov 2026 16:25:03 +0000
How to fix floating tables
View Count: 474
| [2025-07-22 18:23:35] |
| User971648 - Posts: 2 |
Hello can you pls help? I am going crazy with trying again and again and failing. All I want is the following: I simply want to have ONE page/tab with all Trade Management Windows. I have set them up and crated a CW called Trade Management but it seems that they are all FLOATING tables and are not staying in ONE page. Either they all are appearing in ALL of my CBs, over my charts and DOMS. Or, if I remove them from my Charts Books, they are completely disappearing. But what I want is having all these tables, Trade Orders, Trade Positions, Balances, TAL, all of them in ONE page without intruding into other pages/CBs. Is it possible to do so? And if not, what can I do? I want to monitor my positions, balances, orders and I want to have a tap/page with all these tables. Secondly, is it not possible to delete the unwanted COLUMNS from some of these tables? They system is not deleting it. All I can do is move the columns around but not delete the unwanted ones. thanks for your answers in advance! DY |
| [2025-07-22 19:23:36] |
The "Trade Orders Window", "Trade Positions Window", "Trade Account Monitor", and "Trade Activity Log" windows are all detached (floating) windows. There is no way to attach them to the main Sierra Chart window to have them align to that window. There is not a way to remove columns from these windows. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-22 20:47:58] |
Is it not possible to create a Trade Management CB or a page with all the floating windows in that page? Or do you have any other way to have all these trade management functions in one place, window?
| [2025-07-22 20:59:24] |
We do not have a single place for each of these items. They are separate windows as they track different information.
| [2025-07-23 11:15:21] |
| bozo_j - Posts: 51 |
@User971648 Here is an idea for you that can help, which I use. Just create another Virtual Desktop and put all that crap that you don't want to have on your primary desktop over there. It will still be accessible with a simple keyboard shortcut or swipe on a trackpad, and it works remarkably well. If you need some window on the primary trading screen, just temporarily move it back there, e.g. Trade Positions window, and then send it back to the second desktop when you no longer need it. |
