Date/Time: Wed, 25 Nov 2026 22:20:59 +0000
SPX
View Count: 692
| [2025-07-22 15:38:33] |
| User841161 - Posts: 357 |
I know you can get ES options are SPX options avaialable?
| [2025-07-22 16:01:20] |
We do not have any options data for U.S. Equities, so there is no data for SPX options.
| [2026-01-10 15:57:53] |
| UserAR - Posts: 102 |
Hi John, actually I can get SPX and all options data through IB in Sierra and do trade options through Sierra. The only issue, which I'm hoping you can help with, is I am not able to use limit orders with SPX options. Meaning I can make market orders for SPX options only. Options on equities are no problem- I can trade them through the DOM as expected. Any suggestions? Thanks
| [2026-01-10 20:26:29] |
| Sierra_Chart Engineering - Posts: 25484 |
Why is this the case?: is I am not able to use limit orders with SPX options
Is there some error given in the Trade >> Trade Service Log of Sierra Chart after submitting the order? If so, what is the error or what exactly is the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-10 22:10:11
| [2026-01-12 16:47:10] |
Here is the relevant trade log information. The first ones are limit orders that get rejected. The second ones are market orders that are processed. 2026-01-12 08:22:33.121 | Trading message from IB: The price does not conform to the minimum price variation for this contract. Error Code: 110. ServiceOrderID: 116397. InternalOrderID: 111220. 2026-01-12 08:22:33.121 | New order rejected - The price does not conform to the minimum price variation for this contract. Internal Order ID: 111220. Service Order ID: 116397. Symbol: SPX-OPT-20260112-6970-P-SMART-100-USD. 2026-01-12 08:28:10.264 | Trading message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed. Error Code: 2109. ServiceOrderID: 116402. InternalOrderID: 111225. |
| [2026-01-12 18:59:46] |
The error is telling us that the "Tick Size" is not set appropriate for that option. What is the "Tick Size" you have set for that option? And do you know what the Tick Size should be for it? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-12 19:04:40] |
Yes, you've found the issue. I just changed the chart to auto set the tick size from the data field. It's .05 for SPX. It's working as expected now. Thank you so much!
