Date/Time: Wed, 25 Nov 2026 16:25:08 +0000
study with a bracket order teton
View Count: 494
| [2025-07-21 15:00:26] |
| DonForex - Posts: 4 |
Hello Sierra Chart Support, It s possible to create a study when a trigger is activated to send automatically a bracket order , for example on micro nasdaq on teton , 2lots market entry , SL 2 lots at 24ticks , tp1 1lot at 70ticks and tp2 1 lot at 200ticks . And at what should i pay attention , i achive it with only 1 Takeprofit and 1 Sl . Is there anyone I can collaborate with or hire for paid guidance? Apologies in advance if this inquiry is against the rules. I wish you a profitable week and want to express my sincere appreciation for all the work you do to support the community. - Sebastian B. |
| [2025-07-21 15:54:28] |
| Sierra_Chart Engineering - Posts: 25481 |
You say " trigger is activated". What is the trigger in this case? Yes you can definitely do what you want. There are other users on the board who can help you with this but we want to understand more details. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-21 18:35:51] |
The trigger is a fibonnaci level and a candle close above for long and below for short . Thank you so much for your answer! |
| [2025-07-21 21:26:14] |
The "Trading System based on Alert Condition" would work well for what you are trying to do. Refer to the following: Trading System Based on Alert Condition If you want help with how to set this up, then we recommend contacting one of the people at the following link: Sierra Chart Personal Assistance You can also try people at the following link, but these are more for custom studies, but there should be a few people in the list that could be helpful: https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
