Date/Time: Wed, 25 Nov 2026 16:25:07 +0000
New DOM column easy suggestion: Current traded total volume DELTA
View Count: 954
| [2025-07-21 14:50:53] |
| BenjFlame - Posts: 353 |
Hi, this would be very easy to implement for Sierra Devs, i'm missing this that I have elswere and it would benefit many dom traders. A new dom column "Current traded total volume DELTA" that would be the delta between "Current traded total bid volume" and "Current traded total ask volume". Also there should be a shortcut key to reset this that would clear all column's data. Date Time Of Last Edit: 2025-07-21 18:07:34
| [2025-07-21 17:51:45] |
We take all suggestions but we can not say when we would get to any particular item. You can create a custom study to do this. Refer to the following for a start: ACSIL Interface Members - Functions: sc.GetCurrentTradedAskVolumeAtPrice() https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-21 18:08:26] |
Thanks but I'm not aware that it's possible with ACSIL to create data in specific columns in the DOM. Or is it possible ? |
| [2025-07-21 20:13:01] |
Refer to the following: ACSIL Interface Members - Functions: sc.GetDOMColumnLeftCoordinate() For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-30 14:49:52] |
| Sierra_Chart Engineering - Posts: 25481 |
Yes we can add this and we will look into doing this: A new dom column "Current traded total volume DELTA" that would be the delta between "Current traded total bid volume" and "Current traded total ask volume".
But we think you are wanting ask volume minus bid volume. There may be complications though with supporting volume bars for these. So that may not be supported.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-30 14:51:01
