Date/Time: Wed, 25 Nov 2026 16:25:12 +0000
[Programming Help] - Strange Code Behavior
View Count: 562
[2025-07-21 09:41:11]
User250096 - Posts: 10
Encountered many inexplicable code behaviors when using the following study:
1.During the first load, the value of sc.Close[sc.Index] is 4.2095, but after recalculation, it changes to 5.6320, which is the correct value. This issue occurs across all charts.
2.The variable dir is passed as an external parameter to the function getSumPL, and its value should remain unchanged (in this case, it should stay as 1). However, it occasionally changes to -1 at certain points, even though there is no code modifying it within the function.At these point, sc.Close[sc.Index] also change into 4.2095.
3.In some cases, when printing sc.Close[sc.Index] twice in rapid succession, the output changes—shifting from the correct value 5.6320 to 4.2095 (observed in Subgraph[4] and Subgraph[5]).
https://www.sierrachart.com/image.php?Image=1753090753713.png
Private File
[2025-07-22 01:24:50]
when I change sc.Close[sc.Index] to sc.Close[sc.ArraySize-1], everything goes right
I find sc,Index goes to 0 at these point, I think is a system bug
[2025-07-22 13:15:29]
Sierra_Chart Engineering - Posts: 25481
There definitively is no bug:
This page may be helpful:
Working with ACSIL Arrays and Understanding Looping
Everything that you are posting is not understandable and is of no value since there is no complete and detailed and surrounding context. The only way in which someone can help you, is to have the source code of the custom study, and to take the time to understand it, and do debugging.
We recommend doing step-by-step debugging:
Step-By-Step ACSIL Debugging
Date Time Of Last Edit: 2025-07-22 13:15:58
