Date/Time: Wed, 25 Nov 2026 16:24:59 +0000
Regarding Backtesting
View Count: 698
| [2025-07-21 01:35:21] |
| ArmaanSingh - Posts: 23 |
Hi, I want to start backtest in Sierra from date 2024-01-01 to the current date for the ESH instrument. But I when I put date and time on replay function, one time nothing shows up and another time the backtest start from 2024-08-12. Can you guys tell me step by step how to do backtest from the date I mentioned above. as it would be really helpful thanks. |
| [2025-07-21 11:11:21] |
| ForgivingComputers.com - Posts: 1256 |
The Chart Settings>>Data Limiting tab determines how many days of data is used by the chart. If you don't have enough days to go back that far (~600 days) then nothing will show up on the chart.
