Date/Time: Wed, 25 Nov 2026 16:25:14 +0000
Spreadsheet System for Trading - Entries Based On Two Separate Criteria
View Count: 515
[2025-07-20 23:17:38]
User483852 - Posts: 19
I am trying to place limit orders using two spreadsheet trading systems on two charts of the same symbol on the same timeframe for two different criteria.
-Spreadsheet Trading System 1 is on Chart 1 and is placing the first trade. It is placing this trade correctly
-Spreadsheet Trading System 2 is on Chart 2 and is supposed to place trade 2 but isn’t placing the trade even if there is a signal to place the trade.
-All of these are on the same instance.
-I had to use two Spreadsheet Trading Systems on two charts due to the following reason:
o Spreadsheet Trading System 1 places a trade on Chart 1 when the first criteria is met
o I want to Scale In and add to the position hence placing another trade when a second criterion is met. I couldn’t do this on the same Spreadsheet Trading System, hence using a second one.
o It is totally fine to display entry price as average
o Both the entries require stops and targets to be placed. Need not be separate stops and targets. Will be good if they are separate but not a requirement.
o Both are using two different Spreadsheet Trading Systems and using two different spreadsheet names
o Spreadsheet Trading System 2 does not give any messages when “Enhanced Auto Trade Signal Related Logging” is enabled so that I could debug the error
-  It would be ideal if one Spreadsheet Trading System can be used to place these two trades
Thank You !
[2025-07-21 10:59:51]
I was able to resolve this.
I switched back to using only one Trading Spreadsheet. Forced a 0 in signal before signaling 1 again. This solved the issue.
