Date/Time: Wed, 25 Nov 2026 16:15:10 +0000
Time Axis Formatting – Request for Rounded Time Increments
View Count: 619
| [2025-07-18 08:48:35] |
| florianh - Posts: 19 |
I'm having trouble getting a clean time axis below the chart that displays useful time increments. Is there a way to quantize or round the time labels to standard intervals—like 9:00, 9:15, 9:30, etc.—instead of irregular ones like 9:01, 9:22, 9:37? Most trading platforms follow this convention, as the time axis is meant to provide a quick and clear overview—not confuse the trader. Thanks in advance! |
| [2025-07-18 13:42:20] |
| Sierra_Chart Engineering - Posts: 25481 |
Provide an image of the chart or Trade DOM, by following these *exact* instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-21 08:41:26] |
https://www.sierrachart.com/image.php?Image=1753087226528.png
| [2025-07-22 15:47:25] |
OK we see. These are 1 minute bars. We will have to add an option, to set a time increment for the timescale.
| [2025-08-05 14:10:03] |
Regarding the prior post, this actually has been added in the latest prerelease. It is in Chart >> Chart Settings >> Scale >> Intraday Chart Time Scale Increment: 00:00:00 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-08-05 14:10:57
| [2025-08-05 15:34:46] |
I tried it, works like a charm, it visually cleaned up all my charts. Awesome! Finally the 1 Min Chart looks neat. Thanks a bunch for implementing this so quick and easy :) PS: Unsure why, but it seems not to work to save this into the chartbook file, after saving and reopening SC it is back at default value 0 Date Time Of Last Edit: 2025-08-05 15:49:16
