Date/Time: Tue, 24 Nov 2026 17:08:59 +0000
Message Log NTP Client messages
View Count: 811
| [2025-07-17 07:25:41] |
| User781731 - Posts: 74 |
Please see screenshot. I keep getting these messages in the Message Log. I think I solved the "Windows error code 1314" issue by running SC as administrator. But the other messages continue to happen. Is there any way I can fix this? It's quite annoying when I'm trying to watching the Message Log for other messages. Thanks |
| [2025-07-17 14:10:32] |
| Sierra_Chart Engineering - Posts: 25476 |
You can disable the NTP messages through Global Settings >> Message Categories. Set NTP Info to No.
| [2026-07-03 03:07:30] |
| 2garin - Posts: 189 |
Are these messages caused by system time update failures?
Date Time Of Last Edit: 2026-07-03 03:32:33
| [2026-07-03 13:10:47] |
To solve the problem you are having, you need to run Sierra Chart with administrator level access: Network Time Protocol Client: Operating System Privileges for Setting Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-07-03 13:11:46
