Date/Time: Wed, 25 Nov 2026 16:39:11 +0000
Single trigger audio alert
View Count: 466
| [2025-07-17 01:44:00] |
| User273277 - Posts: 145 |
I am trying to setup three audio alerts. Each one should trigger a max of once per trading session. The triggers are: When the open+closed net p/l for all tickers in an account is over a profit value (ie. hit account profit target) When the open+closed net p/l for all tickers in an account is under a loss value (ie. approaching account max loss) When the open+closed net p/l for all tickers in an account is under a loss value 2 (ie. hit account max loss) There's no alert option in the Global Profit/Loss Management screen. The logic is already here, and adding alerts here would be most convenient. Setting this up in a Spreadsheet System for Trading Study by adding J10 and J45 in columns K,L,M, or O, P, Q, best case results in audio alerts on every bar. Suggestions on how to get this done? |
| [2025-07-17 06:03:03] |
| Tony - Posts: 738 |
@User273277, Would you consider coding with ACSIL? |
| [2025-07-17 15:38:59] |
The Spreadsheet System for Trading should give you most of what you want, but you would have an issue with the alert repeating if the condition is met and then changes and is met again. For instance, if you reach your Maximum Profit level, you would get an alert, then if your total profit drops to below the level, the condition is false, so if the profit level goes back up you would get another alert. You should not be getting an alert for every bar, unless you have the option for "Reset Condition on New Bar" enabled. Other than this, the only other option would be a custom study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
