Date/Time: Wed, 25 Nov 2026 16:38:58 +0000
Swing high & low alerts
View Count: 627
| [2025-07-16 23:02:58] |
| User582288 - Posts: 3 |
Hi I am trying to create an alert for swing high & low study using alert conditions like (L<ID & SG of swing studies) but its not working for me. Can you please advise how to create alert for swing high & low study.
| [2025-07-17 15:15:50] |
If you want to be alerted when a Swing High or Low is printed, then you just need to check for the subgraph to be non-zero (or true). So to test for either condition, your formula would be the following: =OR(ID1.SG1, ID1.SG2) Where ID1 is the ID of the Swing High and Low study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
