Date/Time: Wed, 25 Nov 2026 16:39:14 +0000
Setting up chart for Euro futures 6E.
View Count: 649
| [2025-07-16 18:49:07] |
| Adigun - Posts: 1 |
Hello How can I set the tick size on the price bar to display all prices for the 6E. I have tried different settings i found online and none works so far. |
| Attachment Deleted. |
| [2025-07-16 19:15:20] |
If you are referring to the Price Scale and that none of the prices are showing, then this would be caused by setting one of the following graphics settings to "White". - Chart Values Scale Text Color - Chart DOM Values Scale Text The first one is used when the chart is NOT in "Chart Trade Mode". The second is used when the chart IS in "Chart Trade Mode". Refer to the following: Graphics Settings: Chart Values Scale Text Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
