Date/Time: Wed, 25 Nov 2026 16:39:06 +0000
Chart one trade another
View Count: 443
| [2025-07-16 16:40:38] |
| User731023 - Posts: 167 |
If I want the chart and DOM to show ES and actually trade MES (MES sent to broker) how do I do it. If you can just say what to put where would be greatly appreciated. Can't figure it out. (Even with instructions) |
| [2025-07-16 17:03:25] |
Enter the appropriate MES symbol in the "Trade and Current Quote Symbol" field and set the option for "Use as Trade Only Symbol" to "Yes". Refer to the following: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
