Date/Time: Wed, 25 Nov 2026 16:39:14 +0000
Different NQ quotes on two instances (Rithmic & Teton) Denali
View Count: 457
| [2025-07-16 15:25:01] |
| tomas262 - Posts: 164 |
Temporarily Denali lagged for some time in the Rithmic instance. See the image attached. What could be causing this? I though trading service selection does not matter and Denali is independent Date Time Of Last Edit: 2025-07-16 15:27:56
Private File |
| [2025-07-16 15:37:09] |
What could have occurred is that you had a disconnect from Rithmic for a short period. When you can not connect to the trading service, Sierra Chart also disconnects from the data, even if the data is coming from our Denali Exchange Data Feed.
