Date/Time: Wed, 25 Nov 2026 16:39:12 +0000
Sierra Chart - DTC protocol / get Price for Open Order
View Count: 540
| [2025-07-16 07:33:21] |
| stefkovic.m28 - Posts: 45 |
Hello, I have sent an Order via DTC Protocol as Limit Order with TP and SL. My limit order was filled, so I can get the execution price directly. But as for the TP and SL, which are both running and open, how can I get the right order prices which took the server? With order info I can get only fill price which is by open status 0. In Sierra window I can see the realized prices, but how to get them via DTC? Many thanks |
| [2025-07-16 13:39:56] |
| Sierra_Chart Engineering - Posts: 25481 |
You can get the details of a working order with this message: Trading Related Messages: OPEN_ORDERS_REQUEST [s_OpenOrdersRequest structure] Client >> Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-16 16:24:25] |
Hello, ok, but there is no field for get the running price for order. There is only option to see the count of orders, or do you mean that in other way? Please for explanation a little bit more. thanks |
| [2025-07-16 22:20:52] |
What is the "running price"? You can certainly get the price of the working order. It is Price1: Trading Related Messages: ORDER_UPDATE [s_OrderUpdate structure] Server >> Client Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-07-17 07:30:02] |
Hello, yes, that´s ok, I understand, but as for open TP & SL, when I call this function, Price1 gives me 0, until TP or SL is not realized. Or I have made something wrong, as for the call the function. thanks |
| [2025-07-17 14:12:08] |
It is very hard from our perspective to help with this. And we do not get involved in this level of programming help. For a working Limit or Stop order the Price1 field is definitively not going to be zero. That is not possible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-17 14:12:35
