Date/Time: Wed, 25 Nov 2026 16:39:20 +0000
Custom Volume by price study
View Count: 528
[2025-07-15 23:41:09]
ipauls_ - Posts: 8
Hi! I need some help.
I'm using the Volume by Price study to display horizontal volume and delta (bid/ask).
Currently, I apply this study twice for the same candle range — once to show total volume on the left side of the range, and once to show delta on the right side of the screen (screenshot 1).
I tried combining everything into one study, and it sort of worked (screenshot 2).
But unfortunately, the total volume and delta bars overlap — one appears inside the other.
What I want is to keep the ability to display them on different sides of the range.
Is there any way to achieve this?
https://www.sierrachart.com/image.php?Image=1752622707885.png
https://www.sierrachart.com/image.php?Image=1752622554944.png
Thank you!
[2025-07-16 14:39:09]
The only way to do this is to use two copies of the study.
