Date/Time: Wed, 25 Nov 2026 16:39:15 +0000
how to place a limit order at a subgraph level in asciil
View Count: 515
[2025-07-15 19:27:28]
SieraChart.com - Posts: 4
Hello, is it possible in asciil to place a limit order 1 tick above or below a study subgraph?
Let say i want to place a a buy limit order automatically 1 tick above the SG50 of the Volume at price thresold alert v2
thanks for your support
[2025-07-15 19:29:13]
You would have to use the "Spreadsheet System for Trading" to do this. You would specify your Entry as a Limit order and you can reference the subgraph you want for what price point to put that order. Refer to the following:
Spreadsheet Systems, Alerts and Automated Trading
[2025-07-16 14:51:10]
Hello John,
Thanks for your reply,
So i guess we can't do it in asciil, only with spreadsheet?
Could you give me an example of the formula to use with a subgraph
[2025-07-16 15:30:39]
Yes, this can be done in ACSIL. We missed that in the original question. It is just a matter of accessing that subgraph information. Refer to the following:
ACSIL Interface Members - Functions: sc.GetStudyArrayUsingID()
[2025-07-16 23:13:10]
Thanks.
But could you be more specific. I wish to know what is the fonction to place the limit order using what you linked above.
[2025-07-17 15:17:11]
We can not be more specific. We do not give programming help as part of our Support.
The one thing we can do is reference you to the following:
Automated Trading From an Advanced Custom Study
