Date/Time: Wed, 25 Nov 2026 16:38:54 +0000
macbook m1 failing to download charting
View Count: 777
[2025-07-15 12:44:46]
User847055 - Posts: 1
Im having problems downloading the charting for my MACBOOK M1 contiuons to say failed downloading only gets to around the halfway point.I was reading up and noticed this:
( Use Single Network Receive Buffer for Linux Compatibility (Global Settings >> Sierra Chart Server Settings >> General >> Special)
[Link] - [Top]
In the case of when you are running Sierra Chart on the Linux operating system by using Wine, it is necessary to set this option to Yes to ensure good network performance, and not have data corruption. Otherwise, you may have these issues.
WHERE IS THE OPTION TO CLICK YES or the drop down menu to find this option on the site
[2025-07-15 14:21:05]
Sierra_Chart Engineering - Posts: 25481
That option is not relevant to installing Sierra Chart. Use the ZIP Installer instead:
Software Download: Sierra Chart Zip Installer
