Date/Time: Tue, 17 Nov 2026 18:09:03 +0000
Delayed data?
View Count: 533
| [2025-07-14 13:45:08] |
| User151964 - Posts: 3 |
Hi, sorry to bother you with something that probably is very simple, I just came back from vacation and I get delayed data, why? as much as I can check, the services are payed...
| [2025-07-14 16:33:16] |
| John - SC Support - Posts: 48555 |
The exchange that you had active in June did not renew on July 1, 2025, due to insufficient funds in your account at that time. You can activate the exchange(s) you want at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
