Date/Time: Wed, 25 Nov 2026 16:38:55 +0000
Market Depth ES and MES
View Count: 616
[2025-07-14 12:06:08]
Temurk - Posts: 4
Hello, I'm trying to view the ES chart and its Market Depth but want to execute trades on the MES. I've configured the settings under 'Symbol->Trade and Current Quote Symbol' and 'Symbol->Use As Trade Only Symbol'. However, when I activate 'Use As Trade Only Symbol', the Market Depth automatically switches to MES instead of ES. Is there a way to prevent this? I need to see the ES Market Depth. You can see the respective changes in the settings and in the Market Depth on the right in the pictures.
https://prnt.sc/v6c43EGRb2KE
https://prnt.sc/r-o-GhKAEzms
[2025-07-14 16:24:45]
If you want to view the Market Depth and data for ES while trading MES, then you need to set the "Use as Trade Only Symbol" to "Yes". Refer to the following:
Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu)
