Date/Time: Wed, 25 Nov 2026 16:38:55 +0000
Triggered Stop Trail order
View Count: 670
| [2025-07-13 07:21:45] |
| Oiltradhder - Posts: 2 |
Hi team, I’m sure I’m just missing something but I just can’t figure it out. I want to use the Triggered stop to enter, but I want it to trail lower/higher to get a better entry when possible. I’ve tried using the Triggered stop trail but if a buy order is set below market it just markets in. Here is an example of what I’m looking for. Market at 105, I want to place a triggered buy stop at 100 with the trigger at 99, once the market hits 99, If the market moves lower, I want the buy stop to trail down with the market until it moves up a tick to fill. Simply put, I want to get the best entry price to buy on a flush candle down. For clarity, the Triggered stop works perfectly, but as soon as I use Triggered stop “Trail” it enters at market, I want the trail to move down to get a better entry, not up to chase. Hope that makes sense. Thanks as always :) |
| [2025-07-15 14:22:14] |
| Sierra_Chart Engineering - Posts: 25481 |
Have a look at the Triggered Limit order: Order Types: Triggered Limit This is not exactly what you want but it is the closest we think we have. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-07-15 14:22:38
